WISA: BeoSound Moment, BL 18, BL 19 + TV via Transmitter 1
Troikus wrote:
BeoMegaMan wrote:
Keep it real simple and just run the line out from your TV (analog) to your Moment analog input. Then use either the Moment remote or get a BeoRemote One to control it. If you have some extra funds you could get the RCV3000 to the transmitter 1 and use your TV remote to control the transmitter 1 direct when using the TV. Once you run an optical or analog input.
Indeed that's something I thought about. But what if the RCA cable is about 13m long. Wouldn't that downgrade the analog signal too much? I'm not an expert, just thinking about it.
BTW ...  I bought the Transmitter 1 second-hand and luckily the RCV3000 was included.
I wouldn't worry about the degraduation of signal coming from a 3rd party TV RCA output. It's most likely not top-notch to begin with to which the length of cable won't really matter. If you  want the purest audio from your setup use optical. Otherwise connect the RCA and just enjoy it. You probably won't even know the difference in casual listening.
The fact is that Phono connections are transmitting the signal at LINE level. So there will be no audible quality loss. Just the same as using a longer length of PowerLink cable. It's the same signal, just using a different cable and connectors (to also support the amp trigger + data etc).
If you were running passive speaker cables, so i.e after the signal has been amplified, then MAYBE you would notice some sound quality loss. But it would still be marginal unless you went over a SERIOUSLY long length.
In summary, there is no need to worry in your case!
This is not an option, since there is a 1-2 second delay on the line-in on the Moment, your picture/sound will be out of sync... I have thought of this for a long time, but asked BeoCare, and they say it is not possible..
/Weebyx
This is not an option right now but future Moment software update will give the opportunity to suppress the delay (according to a B&O reseller)
I will be looking forward to that, according to BeoCare, the BS35 and the others can havde this delay dissabled, but not the Moment because of its design.
But lets wait and see then :)
/Weebyx
The update that allows you to adjust the line in delay as been out for sometime now. You most certainly can use the Moment as described earlier.
Interesting, I don't see this option on mine which is at the latest software version, would you be kind to let us know the path to the setting ?
I have a Beovison Avant and 4 Beolab 18 + 1 Beolab 19 connected with WISA. All work fine. Now I habe a Beosound Moment in the same room with Network Link to the Avantm because I want to use the same speaker (2 of the Beolabs). The problem is, that the TV always must be on when I want to listen to my moment. The Power Consumption is very high.
Does anybody knows another way to connect the Speakers?
greetings
Mirco
MircoHH wrote:
greetings
Mirco
I have my Moment connected to a BV11, to use the connected Beolab 3:s. When I play the Moment, only the green light goes on and the screen turns on a short time to display e.g songs playing, on the BV11. Thereafter the screen shuts down. Should be the same on the Avant I assume, so the powerconsumption should be minimal.
Yes, this is the same, the avant do. But the power consumption is aboutt 140 W/h.
Is it possible to connect the speaker directly to the moment?
