Greetings!
I have been searching for hours now but couldn't find an answer so far.
My setup is as follows:
BeoSound Moment connected via WISA to 2 Beolab 18 and one Beolab 19. This works perfect. Now I thought it would be quite cool to connect my non B&O TV to the BLs. Does anybody know whether it is possible to pair the BLs to the Transmitter 1 in addition to the BeoSound Moment? I assume this will not work as one always has to be the "master" for the BLs and in my case I would have 2 (TM1 and Moment). At least I couldn't get it working. Transmitter 1 (after resetting the BLs) works but then the BS Moment can't find the BLs anymore. After resetting the BLs again I could do a rescan on the BS Moment and add them again.
I also thought of connecting the BLs via Toslink to the TV but this will also not work because I have to switch from WISA to cable input signal and that's not how I want to use it.
I am happy to hear from others what alternative I can use in respect of connecting the TV to my setup.
Many thanks,
Stefan 🙂
