wiring diagram
Can someone guide me to wehere I could find wiring schematics for a DIN 7pin connector (Beogram4500) to two RCA connectors please?
You want the Beogram output DIN pins 3 and 5 to go to RCA Left and Right respectively. Pin 2 is ground.
But if you are making your own lead and only have a 5 pin DIN socket you will need to removed DIN pins 6 and 7 (they unscrew).
EDIT: Pin numbers looking into a 7-pin DIN socket (or looking at solder side of DIN plug):
Login to view image
I would be tempted to purchase one of these ready made leads from our site sponsor:
Login to view image
Hi VinceV,
Incorrectly grounded cables are the most common cause of noise when using turntables. The cable that I make (linked in Guy's message above) is the same one that I make for B&O to use on the Beogram 4000c and Beosystem 72-23, so you can be certain that this is made to the very best quality and correctly wired.
Kind regards, Steve.
You haven't said whether it's the 1978 or 1985 version, but I just had a quick look in the Products library and the service manuals for both are there.
As a Silver Member you will be able to find them here:
Thank you so much 😊
it’s the 1978 version
Thank you for the link too, I couldn’t find it.
Regards. Greg
Regards. Greg
