Wireless 1 - ML connection between Avant and BS 2300 (via converter 1611)
I got a lot of confusing information about possibility to establish a Wireless ML connection in my set-up.
I would like to connect :
Avant => Wireless1 (Room1)
to
Wireless1 => Converter 1611 => BS2300 (Room2)
Is this possible?
Thanks for your help!
I believe not.
Wireless 1 is meant for the distribution of AUDIO to speakers in remote rooms.
Hi
The two wireless units can provide a one way masterlink connection - one transmitting and one receiving.  Assuming that you just want to listen to music from your BC2300 on your Avant system, that can be done.  However, don't expect to hear any TV sound on your BC2300 setup.
Could work for you but depends on what you want to achieve.
Regards
Geoff
