You remind of the other reason I ran out of ML names to assign to NL sources; I have a BV7-40 in the room with the BS9000, and my BL1's and a pair of BL6000's are connected to it for playing music. The video sources that were easily accessible from a Beo4 were taken up. B&O blew it when they added N.MUSIC and N.RADIO and re-used existing Beo4 codes for PHONO and ATAPE2 instead of figuring out how to retain them in the ecosystem just for situations like this.
If you go in the OneApp, go to your Balance and under Settings there is a tab "Get Beta Updates". Under there you can sign up to become a beta tester. This allows you to submit new ideas and issues to the software development team. There is a separate Mozart Beta test going on (with quite a bit of new features being added), and I also found out there is a separate one for "ASE and Halo remote" which is for all the "pre Mozart" Network Link products. I've been on the Mozart Beta for a year, and now just joined the ASE one, as I am requesting that they create the feture to have A6's to operate as Stereo pairs, which Mozart speakers like the Level can. When you sign up, B&O frequently does automatic software updates to your products and the OneApp on your phone. This might be a way to get your issues resolved.
As I've been fooling around with this issue, I've found that the Beolink Converter gets confused after a few days and I have to power cycle it. This could be due to the frequent software updates that come with being a Beta tester.
This has also caused me to spend more time with the Halo, and I'm finding the more I use it the more I like it. I have not been watching much TV, but I think I will start using my Avant 55 with the Halo to see what that is like.
I've never used the line in on the BLC. If you play with that, please report your progress. I have no idea if it is considered an ML or NL source.
You gotta get your BS9000 repaired! I have multiple shops in the US that I've had great experience with.
