Has anyone else had problems getting games on the Wii to fill the screen on an old Avant?
(I have an old 28" curved screen model)
I currently have a sky+ box in one scart socket and dvd1 going into the other (the third one has the avant's video scart cable in it already)
I connected the wii using the red, white and yellow jacks on the top left of the set (if you are looking at it from the back)
the wii is set to widescreen, but wii sports still doesn't quite fill the screen horizontally like it does on other tvs that I've seen - is there something that I'm not doing? (settings on the tv)
might this be solved by getting the official scart cable instead?
at present, whenever I switch the wii on the game comes straight up on screen, which I like.
If I do switch to using scart instead (which I'm tempted to do anyway as it will look neater round the back of the tv) would it work like this if I bought a scart switch box to share a socket with the dvd/sky or should I just unplug the scart lead for the vcr (which I don't ever use)?
any advice much appreciated!
