Wi-Fi streaming adapter for classic B&O
Hi everyone,
I’ve built a Wi-Fi streaming adapter for my own B&O stereo (see image) and now have two working prototypes at home. My dad said that I should offer this to other people using B&O stereos. I’m wondering whether this might interest other owners enough to be worth the effort on making it an actual product. Any opinions on this would be very highy appreciated!
It connects to the stereo’s AUX input and uses Spotify Connect and AirPlay. Built-in infrared automatically switches the stereo on and selects AUX when playback starts, then returns it to standby after inactivity. It has a compact enclosure and USB-C power. The photo shows one of the prototypes beside my system.
So whenever you want to play music, you just pick it on Airplay on your phone/laptop or via Spotify, that automatically sends the remote signal to turn the stereo on, plays the musci via AUX and when you stop the playback, the stereo gets the "off" command via the IR remote aswell. I've tested this with my BeoCenter 2300 and use it daily, but it should also work with BeoCenter 2500, BeoSound Ouverture, 3000, 3200, 9000, Century and 4; BeoCenter 2, 9000, 9300 and 9500; and Beomaster 4500/5500/6500/7000, from what I could gather from the manuals.
Works great for me, but I might be solving a problem that nobody else has, so I'd like to hear some thoughts:)
Here's an image of the setup
Hi ma-sunde
That sounds great.
I would like one - or two.
Where are you located - and how much would you charge?
Hi again ma-sunde
Are you aware of the small Beotooth adapter von Pilatomic?
Have a look here:
https://forum.beoworld.org/forum/general-discussion/beotooth-5500--a-datalink-bluetooth-receiver
This adapter has support for BT only.
However, it works with datalink - meaning it turns on the audiomaster, when played to.
Maybe these two products could ‘cooperate’/‘merge’ - having a small device, which supports BT, Spotify Connect and AirPlay…and uses datalink to turn on/off the audiomaster would be a match made in heaven.
Thanks Millemis! I’m based in Hamburg. I have a second one sitting on my shelf, I can send you just to get feedback. Selling it at low quantities is a challenging due to the Airplay and Spotify regulations: For anything commercial there's a lot of hoops to jump through. Possible, but I assume that this only makes sense at a volume of companies like Wiim...
Thanks also for pointing me towards Beotooth, I wasnt aware of the project. Super cool method, seems like I wasnt the only one with this issue.
I haven’t worked with Datalink yet, so I’d be interested in understanding what the point is in using that over the "emulated" IR remote. The main shortcoming that I see with my device is that you cant control through the B&O remote and you cant do multiroom setup. For me not really important, but that might be just me. Looking at the traffic in that thread, seems like many people want that? And BT of course, which would be rather straightforward to add.
