Thank you for your attention to my question.
Can you tell me how the speed level changed in your first case when routers and Mash systems were used? Has it grown or remained at the same level, but has it become more stable?
You have a whole entertaining story with the replacement of equipment. But despite the fact that Google is pursuing its goals, the replacement was clearly a step forward in stability and speed, which means it was worthwhile.
Thank you for such a detailed presentation and attention shown to my question.
Теперь вы можете зайти в приложение Bang & Olufsen и подключить продукт к новой сети. Часто это возможно с помощью уведомления, которое отображается над вашим списком продуктов.
Good afternoon!
Thank you for such valuable information.
If possible, tell more about the Notification - how it looks, where it should appear, in which section of the Application, and, most importantly, how to connect Beosaund Emerge to the new network using this Notification, if you are not overwhelmed, then explain step by step, please.
And in the second case, if the Notification is not reflected, I have to press +" on the main page of the Application to open the general list of equipment, find BE in it, click on it and what next? To register it again? Or will the App only allow to register a wi-fi network?
