Rivenflush wrote:
I currently have a BeoCenter 6-23 in my masterlink setup which I have STB connected to to watch digital TV. I would like to add a small TV in the laundry room and connect radio and video over masterlink.
What TV should I buy - another BeoCenter or would a BeoVision 6-22 work also?
Thanks for advice!
/Riven
Yes, BV6-22 will work great as a link TV - I had one in the bedroom for years, now it has been moved to another link room.
The problem in your setup might be the BC6-23 in the mainroom - it will work as a videomaster (you want to distribute video via the RF linksystem?).
As far as I know, the small BV6/BC6 has no RF modulator built in, so there is no RF out socket.
But there is always a solution 🙂
Should be possible to connect an RF modulator the the AV1 SCART socket. I must have one somewhere in my house...(?)
Stefan
