Hi Beoworlders,
My dad recently boughty a Beolab 7.2, to add to his Beolab 3's.
What a sound!!! Dialogs (voices) are soooo crisp. Deep bass, strong mids, clear highs, excellent overall sound. (My dad had some trouble with the stereo sound, coming from the Beolab 3's while watching movies/listening to voices).
At this point, he wants to buy a new TV (can't wait untill B&O is going the LG (oled) route), so looking for a new LG Oled or Samsung Quantum 65" screen.
He wants 5.0/5.1 surround in the tv-room, and because the TV will be a non-b&o model, we are looking for a decent AV-Receiver to do the job.
He want his Beolab 3's a front left and right channel, the Beolab 7.2 as center channel and two Beovox C75's as surrounds/rears.
Yes, C75's!!! He bought them second hand in mint condition last month and made two selfmade/designed floor stands for them.
The black 'base' is in the same design/dimensions as his beolab 8000's (in another part of the room).
They look sóóó good with these floorstands:
Login to view image
I've looked at several av-receivers and found the Marantz SR5010 suitable (very good price at the moment and does everything he wants).
We need to connect the Beolab 3's, the Beolab 7.2 and the Beovox C75's to this receiver and this is where I need your help:
The SR5010 has a 12v trigger output, which I want to use to trigger the Beolab's on/off.
I don't want to use a 220v triggering kit, like Steve from Soundsheavenly sells (I have this triggering kit lying around, but don't want to use it, because I want all Beolab's go on when I switch on the receiver automatically.
(@Steve from Soundsheavenly: Do u also sell rca to powerlink cables with the 12v trigger jackphone connectors?)
Which adapter cables should I buy? What options do I have? Only 'Powmasscables'?
(We live in The Netherlands)
And how can I connect the Beolab 7.2? Because this is 'stereo-speaker' (has build in left and right channel amps). Can I use a simple 1xmale rca to 2xfemale rca splitter cable, together with a triggering cable to make this a dedicated center speaker, with these wiring:
Thanks,
Tim
