Thanks Cleve for your comment! But I have already 3 pairs of speakers and just wondering whether my BC9500 will work with CX 100 as good as with P45? Do you have such experience? When I connected CX 100 to Beosystem 5500 they sounds great, just bass is a little bit "thin". It was just to check how they work. Otherwise my BC 5500 is connected with BV Penta...fantastic sound π, clean, crisp and exact highs, adequate middles, very responsive and accurate, and good enough bass, just what I need as a bass.
I started this post because I'm not sure how P45 will sound with BC7700? Is it worth to connect both and I'm not sure if the amp of 7700 have more power than P45 needs.
A lot of questions, isn't it? I have made a small experiment-I connected BM 3000-2 with S 45-2 and they sounds great! There is no even small sign of distortion in very high volume levels (max!!!). I was really surprised how clean sound BM 3000-2 and S45-2 produce.
So to finalize to your post-probably I'll need only of 1 pair of speakers-for BM 2400 and wondering which will be the best match?
Mitko
