Which system for a small office?
OK, you guys have just about convinced me that my 8000 system is too large for my small office.  Power and space!  Which smaller system has been considered the most reliable and the most for you money?  5500, 3300 or other?  Thanks for all of your advise.  This forum is very friendly and helpful.
I should have joined long ago!
Sorry to keep replying to your threads!
A 5000/5500/6500/7000 stacking system would take up a small amount of space, and some CX50s or 100s would be similarly compact.
I guess it depends on what source you're planning on using? Do you have to have a record deck and cassette deck? If not, then you could pick from one of many older Beomasters and perhaps hook up to your computer? For our home office I have a Beomaster 6000 Quad that's being repaired, and when I get it back I plan to try it out there first with some CX50s and connect it to an Airport Express so I can stream music straight from my Mac laptop. It might be rubbish - I don't know yet!
Depends what sources you want but an Ouverture with Beolab 4000s when bought second hand will be very good value for money. Compact and powerful.
and it just so happens that I have a fantastic overture for sale!!
Send info and photos to durr3 at bellsouth dot net
thanks
John, I had a Beosound 2 connected to that BM6000. Sounded very good, that was not through CX50's though. Can't see any problem with using CX50's though. Most BM6000's seem to have been suppied with P50's.
Craig🙂
The P50 was designed for the BM6000 as the top of the range speakers were considered too large to have 4 of them in an average room in the 1970s!  THe BM4000 was suggested as the top of the (non Quad) range to be used with 5700 and perhaps a pair of 2702 as the smaller ambiophonic speakers.  I would think that 4 CX50s would produce a reasonable sound - but not as good as the P50s which had more dirvers and a larger volume.
Brian
Once had a BM6000 quad with 4 Beovox M75's. That did need a lot of space. P50's are very nice speakers too. Had a couple of pairs of P Range speakers. Never kept any though, just had a play then sold them on.
Craig🙂
Fully agree. I have an Ouverture and Beolab 3s in my office, which is great. Another good option would probably be a Beosound 1.
Hi Durr,
Just my 2 cents... whilst the 8000 (and depending how componants you plan to use) is probably to big for a small office, my thinking is if you have the physical space to place it in the room and since you are already have a mint condition working unit, why not try to use it?
Whilst also, you won't be able to use it at its full potential, you will find that these systems even at low volumes are a joy to listen to, as they have great depth and clarity. Often late at night I will listen to my 6000 at volumes less than 10 (0 - 60 scale) with some nice jazz or classical ......
So food for thought.... to go with some of the other good suggestions above for a new unit or back to the original idea of some 'smallish' speakers....
Good luck!
Laurence
