Which speakers for open plan dining room and how to connect?
I don’t know if the BV11 is WISA capable, but if not, you can buy a transmitter : https://b-o-f.dk/produkter/beolab-transmitter-1-i-hvid
And send the sound wireless to the newer speakers, 18’s, 17’s and the 19 subwoofer. You can also get a receiver you plug into older speakers like your 3’s or 8000’s so they can receive sound wireless to.
Sorry, i meant the BV11 of course.
And now i just found out, that i can edit my replies 😁
Brian wrote:
Thanks Mikipedia, I had no idea about the speaker group options on a BV11... I just bought the TV and stored it away until our house I finished.
In the meamtime you could read this to learn a bit about, what you new tv is capable of:
http://www.tonmeister.ca/wordpress/2014/08/04/bo-tech-combinatorics/
just to be independent from the TV and/or for casual listening i would feed the new speakers with an Essence or a Core.
Thank you for all the replies guys - food for thought.
I will run a pair of rj45 leads from the two pillars to the BV11 before we plaster to cover all bases.
Photos to follow in due course.
Make sure they are shielded cat cables, i went with cat 7 just because they’re the best so far. And imo it’s worth it just to stop any interference you may have or get over the years. We’re all waiting for some photo’s 😁
