Hi all,
after extensively researching the possible problems of my B&O setup, I'm realizing, that one of the main issues is my wireless router. I am using a german brand called AVM Fritz Box 7360, which, according to german media, supposedly is the best router for private use. Also, I have attached an Apple time capsule to that router, so basically, I am using two wireless networks.
All devices that are using the the Apple network, perform without any issues. The Fritzbox, which is the network for all my B&O stuff, is a desaster however, it is a gamble, whether my devices can find and login to the network. More than ever I get network errors. Even if I try to log in to the Fritzbox network via iPhone or iPad, it gives me a connection error. Our wireless alarm system for our appartment from Daitem is also connected via LAN to the Fritzbox.
To make a long story short: what routers do you use for your wireless B&O equipment, especially the Moment, Beosystem 1/2, Beovision etc.? Are there any setup advices you can give me?
Thanks in advance!
