I had a Sennheiser cordless couple of years ago. Although I like the Sennheiser products, I never really used this one because of the poorer signal quality. As technology moves on, I would recommend that you agree with your respective dealer, that you try the headphones in your home, and then you're able to make sure that the performance in every room fits your expectations.
Today I have Form 2, and since one year I'm using the Bose Quiet Comfort 15, which have for my ears a superb, transparent and at the same time voluminous sound with rich bass, independently of traveling abroad or listening at home. It is especially adapted for the apple mobile products but works also fine with my B&O equipment. I do not know, if Bose is offering a cordless version, would be worth a try from my experience.
Kind regards,
Rolf
