Which 'MK' do I have?
I've searched as best I can but can't find the answer to this!
I've been lucky to have purchased a Beovision 7-40 TV which I was informed was a MK5.  However, the info I've gleaned on here and the internet seems to indicate that the MK5 came out in 2010 and my TV has the legend 'B&O MMIV' (I'm guessing this is 2004).  The label on TV reverse says [type - 9644] and [Item - 1807487]... can anyone give guidance?
Many thanks.
I’m pretty sure the 2004 refers to when the 7-40 was launched, not its Mk 5 variant.
Thanks Chris.  Is there a definitive way to tell which 'MK' it is?
Look for the type number on the white piece of paper on rear. Should be four numbers then google it.
To tell the exact age you need the serial number it is 8 digits starting with 21* or 22
type 9644 should be MK5😊
Søren
/forum/general-discussion-and-questions/major-difference-in-bv-7-40-mk4-mk5-amp-mk6#post-1984699
Major difference in BV 7-40 MK4, MK5 & MK6
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
