Hello,
There is been post a lot of the type of lasers for the BS9000. I’ve replaced a couple now and the best result is a spinning cd, successfully focus but no sound. The mute and FM working so the pre amps work.
Its the BS9000 mk1 with the upgrade kit with PCB42. Which laser module should fit with that one? The VAU1255?
Thanks for the help!
