BeoFrederic wrote:
I hadn’t considered the 18s - or the 20s, for that matter.  You rarely hear much about the 20s.  I’m leery of B&O products that require software.
I've had the 20's for 3,5 years now and would definitely recommend them for sound quality (they sound magnificent), but NOT if your dealer is far away. I've had to return mine to the dealer twice for technical issues.
