Hello everyone, am a first timer here so be gentle. Am about to run a master link around the house to link everything together, but what i nead to know is which would be the best coax cable to run around too. want to link sky, pc, main tv in the lounge, kitchen tv. all the cables are internal and nead to be able to carry HD picture too. Thanks for any info in advance...Dave
Which coax cable?
Hi Dave and welcome to the site.
If you want to use the B&O link standard, you are linking data/audio with masterlink and data/audio/video with masterlink+coax. For the video, B&O uses multi-channel RF modulator which means the source emits PAL or NTSC signal on a specific frequency to be decoded only on the desired link set. Due to the type of signal and the decoding/coding operation, you will not have a HD signal (the output would have to be DVB broadcasting but B&O is not there yet). Also, Masterlink is analogue stereo.
Boxes (transmitting decoded signal, not broadcast signal) like Sky, DVD, HDR, beamers can use HDMI, DVI, component or RGB interfaces for transmitting HD content. Non HD content can be transmitted through composite and s-video interfaces.
For your PC, depends what you want to do. For music/video, you can use BeoPort with a coax to a dedicated video card: this way you can play mp3 from your computer to your B&O sets, listen music and video from a B&O set on your computer.
I hope that helps.
For SD (Standard Definition) RF transmissions from the master "Link" output of a Beovision to the link rooms I suggest you use double screened CT100 or FT100 coax cable as below
Example of pricing for this cable is HERE
| Fig. Fig. 2: Different types of dielectric. Top left, foam dielectric used in type B cable. Top right, semi-airspaced used in type D cable. Bottom left semi-airspaced used in type C cable. Bottom right semi-airspaced used in type A cable. |
Because everything else is a waste of energy!
For a short indoor connection between TV's is there any benefit in buying some of the super expensive IXOS or QED coax cable, or would the Maplin cable Keith suggested above suffice?
I would happily buy the cable recommended by Keith. Anything more expensive is likely to be a waste of money.
Do yourself a favour and run a Cat5e network at the same time !!!!! Also consider the following uses of cat5e cables:
Cat5e can be used to carry HD signals.
Then again Cat5e can be used to carry virtually anything you like and is v cheap..................
masterlink has done us proud but is on its way out......................
Umm regarding the cables insulated with air, AIR is not a screen against electromagnetic interference! What a load of cable hoop-lah 😂
People who spend that much (150 pounds for 15m) on cables make me want to cry
It's not there to screen, it's the insulator between screens and core. The geometry of the cable gives it it's characteristic impedance.
