Where's the serial number of a BV6?
I'm trying to figure out where the serial number of my BV6 is located. It's nowhere on the outside and as far as I can tell, nowhere inside the casing covering most of the connections.
Cheers,
/axl
If you are talking about the bcenter 6 just slide grill to the right and it should just pop out. the serial number should be right in front of you.
Behind the speaker panel...
