Where to stick the puc IR?
Hi guys,
Is there a list that explains where to stick the puc IR receivers on each device of the market?
If it doesn't exist, that would be great to make such a list explaining where's the IR of each device.
I start with the Apple TV 2:
The IR receiver is on right of the white LED (about 5mm)
Do you know where is the IR of the TVIX Slim S1 Duo HD?
Cheers,
Hi Edouard
If it is at the same place like the Tvix 6600, the IR is at the bottom of the right corner of the screen.
I hope you'll find it.
Quim43 wrote:
Hi Edouard
Thanks Quim!
I think found it :)
Cheers,
Brilliant 💡 !
