Does anyone know if the BS8 fades out when the power is turned off, and fades in when turned on? At least that would give it a little B&O credibility. The BV8-32, embarrassingly, doesn't have the electronic curtains. Wish they would come out with an update to fix that problem.
Just read in the user guide that there's no "source" button to switch between iPod, USB or AUX-in. Instead, the BS8 accesses the ports in the order of iPod - USB port - AUX-in. The user guide specifies that for the AUX-in to be used, no iPod or USB can be hooked up simultaneously. Seems rather inconvenient. What if I docked my iPod for charging, but wanted to listen to something through the AUX-in at the same time?
Doctor: are you sure it can be used as a link speaker? It doesn't have Masterlink - at least, the user guide doesn't say it does. I guess one could adapt a Masterlink or Powerlink cable to phono L and R and connect to the BS8 that way, but that would be very inconvenient. And you can't change tracks or source.
Leo
