What's your LIST?
While we are waiting for Beo5, we may compare what is the "final" LIST on our Beo4's?
I control an Avant masterlinked to an Ouverture with an Ridax-iPod (link-version) connected. My list is in order:
FORMAT
SPEAKER
STAND
AV
N.MUSIC
CAMCORD
CLOCK
SOUND
TURN
Steinar🙂
Mine is:
FORMAT - used more and more unfortunatly as either the danish tv channels have started sending their signals differently or it is my co-operative union who is supplying my TV signal that has changed something. So the picture is small, and I have to press FORMAT 2 to zoom in, and then it get's a little grainy :o(
SPEAKER - for when I switch between 2 and 4 speaker mode
STAND - for turning the TV set so I can watch it from the dinner table :o)
CAMCORD - for my PS2
V.AUX - for my external 40£ region-free noname DVDplayer, so I can watch other regions
AV - used with the VTAPE input so only the speakers turn on, as my PC is connected here
7) PC - Accessing the Mac Mini and visualize it on the BV7
6) A.AUX - We use the Apple Airport Express connected to the BS3200. Music on the laptop can be transferred and played back throught the B&O loudspeakers.
5) FORMAT - Mostly used for manually pushing the image 1cm downwards when it's in FORMAT 2 mode
4) SPEAKER - When we watch Crime Scene Investigation I switch from 1 to SPEAKER mode 3.
3) STAND - Manually turn the stand towards my present position.
2) N.MUSIC - Stored music (8gb) on the Mac Mini availible with the touch of a button.
1) N.RADIO - First LIST item to select it even in the dark.
SPEAKER
STAND
FORMAT
CLOCK
P.MUTE
SOUND
P-AND-P
Mostly the same, but V.Tape2 at the top as it activates the Panasonic DVD/HDD/Freeview player via my DVD controller from my AV9000. N.Music is top of the one in the other room and I can't remember what the others have!
As my BeoVision 3 32" is not connected to anything else from B&O, my list is quite modest.
FORMAT - i'm using it quite a lot, because our tv channels are now mostly streamed in a 16:9 format inside a 4:3, so you get a black frame inside the screen, if you know what i mean.
CLOCK - it's just useful.
CAMCORD - for my Playstation 2 ( allthough i'm still searching for a way to register it as a V.TAPE ).
Mine is as simple as it gets:
1) Clock
2) Format
3) Speaker
4) AV
The first is the most used - will the Beo5 have a clock on the display? and the Format is only used as most of the motorsport programmes on ITV4 insist on swapping format between the adverts - most annoying.
