I guess that in the Din B&O Connector one pin is just a trigger to activate the speakers. Steve from SoundsHeavenly sells a connector with a trigger, a transformator 230 V -> 5 V 1 A max.
Do you think it could be possible to activate the Beolab 7-4 & 2 by usin instead the the trigger of me pre/pro HC (Emotiva UMC-200) ?
My Emo have 2 triggers output, they have a max of 100 mA. Is it enough? Tx a lot 😮
Here is the UMC-200 Manual: "16. Trigger Outputs (2)
These two trigger outputs can be programmed to control other trigger-enabled devices
(typically they are used to turn on power amps, or amps in different zones, or possibly a
sub-woofer). Each trigger output can be independently programmed to turn on specific
equipment when certain zones or inputs are selected. Maximum current draw on each
Trigger Output should not exceed 100 mA."
