What is the smartest option to control everything with one remote?
Yep, just search remote on the app store. It's the second or first one.
That is the one i have also. It is called ''Remote''. Thank you for the info though.
Yeah, the "remote" app is great..and at least for me it has a much better and faster response with the Apple TV using the iPhone instead of the Apple Remote, even better than the new sleek one in aluminium. I am looking forward to check out the L5 Remote from www.l5technology.com which will be B&O compatible later on..
BeoChime, regarding why Beo4 and Beolink 1000 doesnt work on the aTV is because B&O operate on another frequency ( thats why it doesnt work to control B&O equipment with most universal remotes, and also why L5 will be compatible later on.)
The Beo5 must be operating with both the B&O frequency and the "normal" frequency that is used by most other brands then i suppose..
Still pondering which way to go here, and actually a bit disappointed by how complicated B&O makes it sometimes... the BV-3 STB controller not being compatible with the latest upgrades and aTV ( if I understood that right) and also, as i posted in the Beogram forum, its not possible to use BV3, BS2300 and Beogram 3300 together whitout yet another tailor made box and a bunch of cables..that really sucks..
But I guess I am already in too deep, so no turning back :-)
/Peter
