What is the better way Beosound essence slave or master
Thanks, for this complète answer.
When I receive the Beosound essence, I will say to you how I configured it.
Thanks all
Sure that would be a(nother) way to use it.
Since I still have a couple of masterlinked rooms (and even a MCL-room), I choose to do it the other way 'round.
That way I have the sources of the Essence available in all rooms...
....including in the room with my new (second) tv, the V1-32 (without having to use the converter).
The Essence is a very 'flexible' device - fits in everywhere ;-))
Thanks CB.
Thanks CB.
Hi everyone...as per my experience one way you could do it, is to use the PowerLink-out (you'll need an adapter cable) to connect the Essence-box to the Aux-input of your BS4.The Essence will have to be configured as 'fixed line-out' and you won't be able to use the 'wheely-remote' for volume controlling! This will have to be done with the BS4. The Essence has a line-in connection, which has autosense.
How configure the beosound esence for use the "wheely remote" volume ?
How to " fixe line-out" on the Essence? Can you give me the solution?
Thanks.
