Nwisni wrote:
I have interference on the wireless transition when using a microwave. Would this improve with the sofware update?
A Microwave oven can often cause interference to any Wi-Fi and similar devices depending on type of Microwave, power, screening and placement.
B&O's installation manual states:-
The Beolab Transmitter 1 has an omnidirectional transmission characteristic, although this can not be an ideal sphere.
The transmitter and the receivers of the loudspeakers must have line-of sight.
The transmitter and the speakers are placed inside an area that is recommended to have the maximum of 9 x 9 metres / 30 x 30 feet
The distance between the Beolab Transmitter 1 and any receiver must not exceed 12 m / 40 ft.
Ideally there must be placed no objects between the Beolab Transmitter 1 and the speakers - especially not objects consisting of material that will block or totally material that will block or totally reflect the wireless signals.
A software update if available is unlikely to improve this interference problem.
How old is your microwave oven, if over 5 years it may well have limited RF shielding
