What IR-codes does a beomaster 6000 / 8000 use?
I have a cunning plan about building a beosystem 6000 / 8000 system after I was given a Beocord 8002 and i already got a beogram 6002. But what IR-codes does the beomaster use, what remote control should i start searching for? I already got a the terminal for the beosystem 5000, is the codes the same?
br
Chr.
Hi Christian.
You should look for the Beolab Terminal.
That is the original one for the beomaster 6000/8000.
Razz
Ok, thanks, I'll start searching, sounds like a good project for the summer holiday. By the way, how realiable are the beomaster 6000/8000? I seem to remember different people in this forum having their problems with keeping them running.
If people are interested, I'll post some pictures when i get the Beocord 8002 up and running.
br
Christian
I have heard the same thing about reliability, but i have yet to encounter my first problem with my setup. The BM 8000 and the beocord 8004. I am getting the beigram 6006 on Saturday:-)
What kind of speaker are you planning on using?
