This might be a silly question, but one of the silver strips that runs down the length of the back corner of Beolab Pentas (hope that makes sense) is peeling off on one of mine, and I just wondered if anyone had any recommendations for the best type of glue to use to stick it back on? Thanks
What glue to fix my Pentas?
Don't use glue but rather double sided sticky tape.
Thanks Stonk, that looks like it should do the job. I've ordered some and I'll report back to confirm if it's worked in case anyone else has the same problem.
I had the same problem on my Pentas. I used double sided carpet tape and its fine now. The only issue I can think of with the tape you have got is that it might be too thin. The tape I used was approx 2 inches wide.
