What does the DPL do on the Core?
- double -
seethroughyou wrote:
Tried that this evening several times and it doesn’t work sadly. No sound at all. Maybe your BL20 has powerlink cables attached to it.
One thought.....I think that if the 50s/90s internal volume control is turned all the way down, then the app control you tried will not work. When I used the app control as you show, I had to have the 50s volume control turned up a bit, if I remember correctly.
Razlaw wrote:
One thought.....I think that if the 50s/90s internal volume control is turned all the way down, then the app control you tried will not work. When I used the app control as you show, I had to have the 50s volume control turned up a bit, if I remember correctly. Beolab 50s Beolab 9s Beolab 12-3s Beolab 1s Beolab 6000s 2 pairs Beolab 4000s Beovision 7-55 Beovision 10-40 Beoplay V1 32 inch Beovision Avant 32 inch Beosound 1 (CD player) Beosound 3000 Beosound 5 Core Essence MKII Beoplay M5
Thank you Razlaw. When I turn up the Beolab 90 default volume the volume dial moves on the app playing the Core. If I later switch over to CD via SPDIF, the volume is so high it sounds like an explosion. The default volume is too high for other sources.
I’ve unticked the ‘volume regulated output’ option on Toslink on the Core. I’ve gone back to using an Essence remote. The only other option is to feed the CD and record player into the Core’s input and pass all sources through the Core and then use volume dial in the Core app and do it all in the app.
If you’re playing a CD seems daft to open an app just to change volume. Better to use Essence physical remote.
If you’re playing Deezer in the Core on the app, seems sensible to do volume in the app but seems daft to use the Essence.
You can’t have the best of both worlds.
It is a problem. I am hoping that maybe the Halo will simplify it a bit when using the Core.
Seethroughyou, do you also use a record player? I can’t remember? Because I was going to suggest maybe getting a beomaster 7000 or similar and use the preout of that and that way the beomaster will control the volume of the cd and possibly record player. Just an idea as that’s how i have it here atm🙂
