What are you working on now?
Looks great!
Could you post a link for that display or just the name?
Showing what is playing/the cover art is a great idea.
https://www.guition.com/esp32-display-module/4-inch-esp32s3-display-module
I'm working on a link for the old Product Configuration Guide" data files, which exist from at least 1994 to 2010.
There were both DOS and Windows viewers for this data, but running them is a bit tricky in 2026.  The viewers ingested "rule sets", which represented a combination of market and language.  You navigate through a series of choices, starting with the Video system, and end up with a "Conclusion" that tells you how to configure various settings, hardware additions, and room options.
The
^ Great work - that looks really useful!
I often use the PCG to answer questions here on Beoworld, but I run it on a Windows 7 Virtual Machine on a QNAP NAS.  A web based alternative will be very useful!
I do have a couple of PCG SW downloads on my drive:  One is called 'Product Configuration Guide (version 2.6.4)' and the other 'Product Configuration Guide27' - I think I downloaded both from Beoworld many years ago, hence think that you probably have these.  Let me know if not.
Further to the above -  I think I just accidentally deleted one of the image attachments from your post (my Moderator powers allowed this as I clicked 'delete' instead of 'view') - many apologies and I hope you can re-add the image.  If not, send it to me and I will add.
Hah, no problem, can re-upload here and add the search interface... :)
If you can send me one of the *.RUL files that are hiding in the Program Files folder for each app (or just the installer exe if you have it?) I can check the versions and dates...
I have now sent you the .rul files.
The two executable files that I have are the ones downloadable from Beoworld at the bottom of the list here:
Bang & Olufsen classic service centre.
Repairs and refurbishment to both old and new.
Happy to share the viewer code and JSON files, it would be great to have it centrally hosted on BeoWorld!
