Hi Guys,
Does anyone know where to get the grey tubing that is hiding the cables running down the wall and across the floor? Are these part of a B&O install or are they third party and where can I buy them?
Hi Guys,
Thanks Mark!
This picture is mine. Cavus.eu sell these cable covers. But you have to buy them via your own dealer. It may be that these aluminium covers (6x4cm) are no longer available.
Fantastic. Thanks Geert.
They are indeed very nice. I had bought the plastic version of it DIY, which doesn't look so nice but still fine. My greater issue was how to actually fix them to the wall. I used two-sided tape, but this wasn't strong enough to really make it stick. Any experience how you did this?
