Hi!
Coming with a very unusual issue - couldn't find anything even remotely similar case on the internet, so any suggestions would be extremely welcome...
Setup:
I have new B&O H95 headphones, using them WIRED;
I have PC with Sound Blaster AE-7 which is reasonably strong sound card, using direct mode with no software disturbing the picture;
H95's auto turn off mode OFF;
Issue: at random time intervals (usually between few minutes and and hour) the headphones just turn off - audio stops, like if they were switched off (but they physically weren't). The source however keeps playing the sound, so if I disconnect these headphones and connect other headphones, or switch to speakers output audio continues playing. For my B&O H95 I need to manually switch headphones off and back on with the physical switch to make them to continue playing the audio...
What makes things more complicated
When I use same headphones, via same cable with my MacBook, everything is fine;
When I use same headphones, via same cable with my PC (one causing the issue) but not via Sound Blaster AE-7 but via front jack panel (which is connected to motherboard/Intel audio controller) everything is fine as well!
No issues via bluetooth either;
In other words the problem only occurs when I have headphones connected via AE-7's "headphone-out". Same PC but motherboard audio = no problem.
I am in contact with B&O support but this but their answer was that the sound card may give "too faint" signal and bye bye - which is ridiculous since the sound card has amp built in and can easily drive headphones up to 600 Ohms (while H95 are 12 Ohms or so), the signal is more than sufficient. It is much more powerful than MacBooks or Intel audio from motherboard...
So I'm lost, I love these headphones for their comfort and versitality but this issue is so annoying and I can't figure out what is the problem (not counting support will help neither...).
I tried tinkering with everything, including power options in Win 10, tinkered with literally every option in audio settings.
I think it's just poor software in these headphones that turn switch "auto turn off" function for some random reason caused by something but it's beyond my understanding.
Will appreciate ANY ideas. Thank you in advance!
