Hi all,
I have a pretty standard setup which has a problem in the video quality over the (master)link to the bedroom MX4002. The signal is send from the video master, the Avant. I have a superb quality on the normal television channels on the MX4002, but the signal from the DVD or HDR1 is weak, filles with snow and low sound volume. The masterlink is ok, radio and cd work fine and I can command the HDR1 and DVD fine. Since the normal tv signal is fine a bad cable or connection is ruled out.
The setup is: TV cable -> HDR1 -> Avant -> MX4002. The link frequency is set to 599 on the Avant, as far as I can see this is the case on the MX4002 as well. Unfortunatly the manual of the MX4002 got lost, and the manuals available online describe a different software version (mine is S/W 2.0). I have no clue how to set the link frequency on the MX4002, and I'm not sure to which channel number it actually coupled.
Apart from this all, do I have to swith the modulator on the Avant ON or OFF? The configuration guide says OFF.... which I don't understand.
Anyone a clue?
Regards,
Bart
