Wall mounted Beolab 6000 - possible with older ones?
Hello all,
is it even possible to wall mount earlier Beolab 6000 or is it only possible with newer Beolab 6000?
regards, Adrian
Should work for all of them - it uses the screw holes for the foot plate and I don't think these changed. I have put the fitting manual on site.
It works fine.  I have 4 older ones mounted in my house
thank you guys for your information!
regards, Adrian
