Volume control Beoplay A9
Hi, just bought an A9 speaker, but I am quite annoyed that every time it wakes up using the line-in it is at volume setting 60. Is there a way to change the default setting to 80, so that I dont have to open the app and adjust the volume every time I use the speaker?
Br
Yes, you can do that in BeoSetup app, under Sound (set default sound level).
Hi and welcome to Beoworld.
You can change the sensivity of the Line-in connection in the Settings using the BeoSetup app.
I have tried to set the sensitivity to both high and low and changed the default volume to "user defined: 80". But still every time the line-in wakes the A9 it is set to 55-60 (hard to tell cause the number does show until I start moving the control wheel). FYI I am using a Sonos connect to provide the line-in feed. Don't know if that changes anything...
Is the Sonos set to a fixed line output?
No it is set to variable so I can use the Sonos app to control the volume.
Then you have two variable volume controls - not the best.
Is this the only way, that you use the A9?
pretty much. Is there a way to set the A9 to volume:80 constantly?
Not that I know of!
You can set a max level, but that is something different.
I guess 'the makers' did not think of that user case.
