Voice coil or capacitor or something worse? Woofer only works when cone is pressed
I have a pair of s45.2 and both have the same issue; the woofer only works when the cone is depressed, either by hand or by turning the woofer on its face. Iv’e checked the braided wires and connections and everything looks OK. The history of the speakers is they were stored for a number of years.
I can see this happening to one speaker but both? Strange coincidence?
I take it that the cones are moving freely and that the magnets have not shifted therefore gripping the voice coil tightly? and have you measured the resistance of the coils?
Craig
Yes to all three, and your comments inspired me to disconnect the speaker and test it out of the cabinet.  After disconnecting it from the crossover and pulling it from the cabinet, it's testing  fine with a 9v battery and I'm showing 4-6 ohms.  I ordered the cap kit from Martin and i hope  it does the job.
-c
-c
Good man......post some pics and keep us informed
Craig
Quick follow up, after re-capping the problem still existed but at least I had eliminated that from the equation.  A a little more extensive testing revealed that it was the soldering point where the voice coil meets the tinsel.  I shaved a little of the black stuff covering the coil wires inside the cone and was able to test the voice coil separately from the tinsels.  The tinsel was worn, so I replaced the tinsel, re-soldered things back in place and covered with black dressing.  I now have a great sounding set of S45 speakers.
-c
