Virgin V+ STB and Avant DVD
A friend of mine wishes to get a Virgin V+ box working with his Avant DVD. He was originally told by B&O that this was possible and made the necessary arrangements but has just been told that the Avant does not have the software for this device. Is this true? I seem to remember that the Pace NTL codes worked for Virgin but is that just an older version? Anyone using this set up?
This is possible (V+) depending on the version of Avant (Only the later ones) It is avalible in the leatest PUC software
I will need to check, but it is a RF Avant DVD32". He said about 5 years old though I imagine a year or so older could be possible. He was told that the software was only for the flat screen TVs and not the Avant.
Peter,
The Virgin V+ box is made by the US company Scientific Atlanta Explorer model 8300HD which is also used under the TeleWest name as well.
This actual STB is not available in any version of AVANT STB chipset, however as Scientific Atlanta appears to use the same IR codes for all their STB's, you could try the "G Sci Atl DVR" listed in the "Western Europe" version 4.01 chip part number 8344785 or "SciTiAtla SABNNKZNS" listed in the "Southern Europe" version 4.03 chip part number 8344787
That sounds good! I'll let him know! He was pretty cheesed off and was threatening to sell all his B&O kit. he did buy a Sony LCD though for another room and found the broadcast picture very poor compared to the Avant - no surprise there then!
If these didn't work, can you get a Beo5 to operate it independently?
Peter,
Making Virgin V+ work directly with the Beo5 is very easy because it uses Philips RC5 IR protocol codes, so an XML file can be created with our "Beo5 3rd Party XML Generator"
I had a suspicion it might - I have offered to lend him my Beo5 if the other codes don't work. Afraid still a paperweight though I have charged it!
Hi All
I have the latrst STB-C in my Avant (4.01 West Europe) and wish to control my Virgin V+.
If I select the  G Sci Atl DVR as the source:
1. Every time I  do anything (e.g. change channel or look at TV guide) the picture freezes for a fraction of a second.
2. I can't utilise the coloured buttons as they are mapped to do other things like go up and down channel.
3. I can't access the menu to view my recordings
I therefore tried the Pace 4000 NTL as the source:
1. No temporary freeze of picture what so ever
2. Full use of the coloured buttons as they are not mapped to do other things.
3. I still can't access my recordings!!
Can anyone let me know what sourced they've chosen so as to control their Scientific Atlanta Explorer, and which Beo4 keys do what?
As always, your help and support is greatly appreciated.
