Some of the series datalink components are compatible, but the IR codes and MCL protocol changed between the 5000 and the 5500 and higher. So you can use a Beocord 5500 and Beogram CD 5500 or higher, but you must use an MCP5000 or terminal 5000 for system remote control. Likewise, you can only use MCL82 with the 5000. The 5500 and higher use the MCL2 boxes and protocol.As far as Beograms, the 5000 can use the 5000, the 5005, and the 5500. The Beogram 6500 and 7000 have internal RIAA preamplification and so provide a line level output that is incompatible with the phono input of the 5000 and 5500.While I carefully collect 5500 modules and control panel, is the 5000 series modules 100% compatible and identical looking? There are some cheap, working 5000 things for sale around here.
Vintage selection - What to mix and match?
Thanks, Dom. To clarify: I'm picking up a Beomaster 5500 and tape deck tomorrow, not any 5000.
But essentially, you say that the Beomaster 5500 can use Beogram 5000, 5005 and 5500 as these players do not have built in RIAA (The RIAA being in the Beomaster 5500). And the design / colours etc look identical for Beogram 5000, 5005 and 5500?
Thanks guys, 5500 master and tape with cx 100 in the house for EUR 150. Smokey smelling.. I'm too spoiled with high end synths that noone would dare pollute with smoke.
Moving to /forum/general-discussion-and-questions/can-people-tell-me-what-exactly-is-the-point-of-mp3-ipods-etc#post-1913828
Yes, they are compatible and have the same pizza box form factor, but I know the later version of the series like the 6500 and 7000 feature a different aluminum finish. I am not absolutely positive the 5500 and 5000 series have the exact same finish. We’ll need others to weigh in on that.
The 5000 and the 5500 has the same finish with the brushed aluminum and the color of the metallic grey plastic surfaces.
Oh wow, I'll definately try that. I thought I'd open it up and use compressed air to blow away things as well. Baking soda + box sounds like something I can do :)
The BM5500 is a very useful device - lots of inputs - I use a BM5500 with CX100s as the sound system for my iMac. I would counsel you look for a CD5500 rather than the CD50. The CD5500 uses the TDA1541A DAC which is fabled as one of the best sounding and the CD player is also quite a bit quieter in operation than the CD50. I had a 5000 system new and bought a CD 50 when it was released, some time after the original launch of the 5000 system. I sent it back as it was simply too noisy! I do have a CD50 and a CD5500 now but the CD50 is once again inoperative - it seems far more temperamental than the CD5500 which is fine if possibly a little overenthusiastic to close at times! The Beocord 5500 should not be forgotten either - very useful device!
