I just bought a used MX6000 which was tested working before.
I attached 2 video games consoles (nintendo64 and snes) both to av-1 and av-2. Both cables are AV-cables, one is chinch for which I got an adapter to scart, the other cable ends is directly a scart cable.
I set the settings to:
AV-1: V-Tape 1
AV-2: V-Tape 2
S-VHS: OFF
Powerlink: OFF
Problem is, the sound works, the video is really distorted, just like a decoded video signal you can barely recognize whats on the screen, most of the time its just flickering.
Anybody know that to do? I can post a video if that helps.
