Just connect a BL converter to your ML system and connect your sonos (you will need an rca to DIN adapter) to AUDIO AUX LINK plug.
BV should be set to V.OPT 2 - should work, but I never tried - I`m using a BS5 .:-)
You don`t really need a Lintronic box, it`s just an option to control sonos with your Beo remote controls,
but of course you can use i-devices or something else....(?)
Stefan
I still do not understand. What do i connect to the Beolink converter? Only ML and then connect the sonos directly to the digital inputs on BL5?
/Ehlz
Sorry to be unclear.
You connect a BL converter to your BV via ML, then you connect Sonos analogue out to BL converter inputs (AUDIO AUX), and connect Sonos spdif out to BL5 digital in. BL5s are connected also via Powerlink to your BV.
For more info:
http://archivedforum2.beoworld.org/forums/t/4302.aspx?PageIndex=1
In addition you can connect a Lintronic box do BL converter datalink. But this setup should work without Lintronic box.
Hope this helps.
Stefan
