Using BL5 in surround setup AND connect sonos.
Hi
As of now, i have my surroundsetup working flawlessly vith my BV 7-40, Bl3´s and Bl5´s.
My question is, can i furthermore connect say SONOS to the BL5´s directly without an audiomaster?
I think i was once told that to use SONOS in this setup, i would need an audiomaster in  ML connection with my Beovision 7, and then when pressing CD, without an CD in the audiomaster, the BL5´s would listeen to the digital input, (in my case SONOS).
So basicly,, can the above be achieved without an audiomaster when i still want to keep the BL5´s in a surroundsetup.?
TIA
Ehlerz
Almando Multiplay should work.
Search for it on this Forum.
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
What about a Beolink converter as an audiomaster?
Connect it to ML. Connect Sonos to Beolink converter (Aux) and digital connection directly to BL5.
Control Sonos via a Lintronic box - connected to converter datalink- in CD mode. BL5 should switch automatically to digital input.
In this way it should be possible to control the audiosystem in a eolink system.
Stefan
Ralf
Beolab5's need powerlink data, so I think you will have no sound.
Why not just use the BV and P.mute the screen? Seems straight forward and no real hoops to jump through...
Well, that is an option, however not my first priority. I guess you mean hooking the sonos up to the AV4 phono input on my Beovision? This way, the sonos will not be connected digitally to the BL5´s, so will i not miss out on the sound quallity?
/Ehlz
Stefan
Interesting, however i must admit that i am not to familiar with the beolink converter and furthermore not keen on having the Lintronic control if i can avoid it :-)
/Ehlz
Just connect a BL converter to your ML system and connect your sonos (you will need an rca to DIN adapter) to AUDIO AUX LINK plug.
BV should be set to V.OPT 2 - should work, but I never tried - I`m using a BS5 .:-)
You don`t really need a Lintronic box, it`s just an option to control sonos with your Beo remote controls,
but of course you can use i-devices or something else....(?)
Stefan
Stefan
I still do not understand. What do i connect to the Beolink converter? Only ML and then connect the sonos directly to the digital inputs on BL5?
/Ehlz
Ralf
The Website says:
Powerlink signals of connected B&O sources simply were looped through. All remaining audio signals by devices of other manufacturers – it doesn’t matter if digital or analogue – are converted into 100% standardized B&O Powerlink signals, including the trigger voltage appropriate for B&O speakers.
Ralf
