Using a Beoport as a Beolink Active
Hi there
are there any caveats to using a Beoport as an Beolink active apart from the fact that the computer will have to be fairly close, as I see this as killing two bird with one stone
Let me know what you think
Simon
2 caveats that I can think of:
1)  The computer must be connected to the BeoPort for music to play
2)  If you're using a Mac, you can only hear N.Music, not other sources.
Stan
Stan
Arde you saying that I can only play N-Music thru the beoport active speakers & not the rest of the systems sources connected to either  to the Audio or video master?
I was under the impression that the Beoport acted like a link room in that you did have access to masterlink sources.
Simon
Hi, the audio-out connection on the beoport (covered with a small black sticker) outputs whatever source is on the link.
