User and Service manuals
Any chance of adding the PCG (Product configuration Guide) software, this was available on the old CC
 Cheers
Steve
I'm after the Beolab 5000 Loudspeaker Service Manual if such a thing exists?
Cheers
SteveB:
 Cheers
Steve
I am sure we will - It is on my list of things to add! Where do you think would be a good place to put it?
Hi Peter,
Difficult under the current structure of user and service manuals (Which works very well by the way) It was always a little tricky to find under the old site. Maybe we need a new category under 'products' for software as it soes not naturally fall under the service manual heading
 Steve
ps in the meantime any chance of mailing it to me
I would be grateful for a copy of the service manual for the Beolab 2500 (if one is available).
 Thanks in advance.
wirralsimon:
Hi
I am looking for a service guide to the BeoCenter 2000. Not a classic by any means but it came effectively free with a pair of S45-2's on the original stands that I bought for £16 on ebay. The problem I have is that it is effectively mono (The sound out of each of the four speakers is the same) and I would like to see the service manual before I  start investigating/dismantling.
 Simon
I'll see if I can locate one though these are odd machines as they are actually Japanese. Not as serviceable as some I am afraid.
I don't need this now!
I opened up the back of the unit and a quick poke around revealed the problem. The right hand channel on the amp has ceased functioning and a previous owner has soldered wire across from the LHS to the RHS so that the working channel was being played through both left and right speakers! Given  that it's in poor condition, not working and far from a classic I shall be raiding it for useful parts (mainly from the turntable) and throwing it in the skip!
Simon
Anyone have the service manual for the Beo4 ?
Thomas
Hi, Stonk.
 Thanks for looking.
