Hi.
I've been guesting on this forum for a long time and there are lot of interesting - and knowledgable - views to be found so I thought I'd ask for this community's opinion on used B&O TVs.
I'm looking to replace a 15 year old Philips 21 inch CRT with something with the style to match my stereo (BC9300+BL8000). I'm undecided between a used Beocenter 6-26 or a BV7-32. There are not many of the former around on the usual used equipment sites but there are quite a lot of BV7-32s. What should I read into that? Are they no good? Is a BC-6-26 OK?
I know all the spec and feature differences between the two - and yes I know ones bigger than the other - but any advice on performance and how pleased I'm likely to be as an owner would be very much appreciated.
Many thanks
