Use of Playmaker without iDevice
Millemissen wrote:
You can have N.RADIO without any problems - if you were using i-devices and AirPlay?
Don't forget you can also use a Windows laptop (or Mac, of course), with Airfoil, to send any audio to the Playmaker, as an Airplay device.
I've just connected a Playmaker to our BL3s in the office and it's possible to stream radio or any content to them, via Airfoil. http://www.rogueamoeba.com/airfoil/
On a sidenote, the Playmaker looks grubby after a few days in the office! 😉
Many thanks for the AirPlay info.  I already have TwonkyBeam on my Nexus, and TwonkyManager on my PC so it appears that I may already be 'AirPlay compatible' without knowing it!
The Twonky forums report a few airplay problems with TwonkyManager, but airfoil does look good as an alternative.
I think I need to borrow an iDevice (or PlayMaker) and have a play ...
Running an HP Mini with Windows XP and iTunes using Airplay, a Samsung Galaxy using DNLA, and an iPhone4 using Airplay to connect to the Playmaker. Only the iPhone is problematic. As per recommendations ob this forum I'll soon do a software upgrade of the Playmaker to see if that helps.
I can't find any mention on the B&O website of which SW version is the latest. Does anybody know?
My Playmaker says 1.00.2485.
In regards to the topic - Can you turn a Playmaker on/off using a beo4?  Does a beo4 give give more options in sound-setup, than adjusting by the source?
