Use BLGW as MLGW Protocol Driver for BLI
Hi All
I have migrated from the BLGW to the BLI but I need to keep the BLGW on the network for the Masterlink connection.
If I keep both the BLGW and the BLI running on the network, all of the Avants point to the BLGW for the HomeControl overlay instead of the BLI
How can I change this so the main overlay for the BeoVisions is the BLI?
Please help.
Thank you.
hi kiran,
have you already found a solution? I have the same problem with the bli in connection with a blgw. I now use a mlgw and no blgw for exactly this reason. (the mlgw has no HomeControl overlay) - in the beovision you can select the source for the integration (bli) but this sometimes changes automatically to the blgw. (It would be ideal if you could deactivate the HomeControl overlay on the blgw - but unfortunately this is not possible)
beoandy
It is not that difficult: just install the driver in the BLI
hi chucky!
the connection between the blgw and the bli is clear to me and not the problem.
The problem isn't the connection, the problem is that the home control overlay is then "output twice". for e.g. the BV11 or avant. the BV11 does not store the source (bli) and use sometime the home control overlay from the blgw. (which ist empty)
the hone control overlay cannot be deactivated in the blgw settings.
I have only ML sources in the MLGW. All NL sources are in the BLI
i would make a backup of your MLGW delete the sources which are NL
If you have double recources in both systems it will execute double. So kill all macro”s as wel in the BLGW and only use the BLI.
Hi
sorry I think we're talking past each other. :-)
I'm talking about the problem of kiran posting #1.
yes, all nl-sources are in the bli. and all ml -ources in the blgw. i have no macros in the blgw!
The problem is that sometimes I have the home control overlay from the bli and sometimes the empty! home control overlay from the blgw on the bv11.
beoandy
<!--more-->So because the BV11 is ML it does not switch in tbe overlay from the BLGW? Sorry I have 6BV  only NL.  The only thing I can think of is linking it again in the BV 11 to the BLGW. Otherwise email Khimo, they will help
