How do you configure a preset to use decoder? I have a MX7000 from 1992 (early one with the BL1000 remote)
Urgent help needed!! With mx7000
As far as I remember in the tuning "menu" that is displayed after pressing "goto".
Pressing "shift" and then "picture" will change "dec off" to "dec on" - you'll have
to store the change in the usual way.
Don't forget to make the required settings for AV1 or AV2 in the "setup menu"
Thank you! :-)
Before your answer I tried a lot of combination of shift and other buttons.
But as it seems; never "Picture" ;-)
Now it works fine.
Then only little downside compared with "V-Tape 2" is that the MX does not start automatically when I start the DTV-decoder. But that is not important.
Easy to just push "TV"
