Upgrade the Tweeter in BeoLab 8000 MkII to High End ?
I haven't done any mod work on the speaker drivers in this
particular model but I have on several others - always ending with the
same result; What was in there originally, was the best.
Keep in mind, that lots of drivers were custom produced to B&O because some
really odd specs were required.
Sometimes an improvement can be achieved by replacing capacitors to other types but
it is my experience that the major part of the improvement comes from simply replacing tired
capacitors with fresh ones, rather then replacing standard capacitors with ones of a more
shiny and expensive type.
Expected lifespan will typically be longer for foil caps than for electrolytics though, which
may be cause enough for some owners to choose them over standard components but
I never saw replacement speaker drivers do any better than the originals in any B&O.
Yes i may have started this thread from the opposite direction.My question was simple, if someone have dun any similar before
A conclusion might be, that noone has done this so far.
We wish BeoLab good luck with his project of making a new speaker using the aluminium part of a BL8000......
....and we are looking forward to hear of the results here.
Period!
Period!
I agree, good luck, and interesting to see the project. Even tough I think the biggest issue with sound is that our ears fade as we grow older.
This thread made me want to try again too fix the bad pair of BL8000 I have, they start to sound strange after a few hours. New capacitors will be my first shot at fixing it.
Maybe you get strange after a few hours...😎
The OP will probably like them no matter how they turn out, parents don't usually notice if their baby is ugly. I've seen this in the DIY speaker crowd more times than I can count...some guy mates a 15 inch woofer with a piezo tweeter, just horrendous sounding. The creator was certain that it sounded great if you just played it LOUD ENOUGH!!! 😁
Sounds like when I'm cooking food. Everything tastes great then 😁.Maybe you get strange after a few hours... The OP will probably like them no matter how they turn out, parents don't usually notice if their baby is ugly. I've seen this in the DIY speaker crowd more times than I can count...some guy mates a 15 inch woofer with a piezo tweeter, just horrendous sounding. The creator was certain that it sounded great if you just played it LOUD ENOUGH!!! Jeff Beovirus victim, it's gotten to be too much to list!
Especially delivery pizza? 😁
