Hi all . Want to upgrade my BeoVision 5 setup to HD , but with the relative low price of panels I can’t justify the high B&o tv prices any more . So I propose to hang a Samsung 46” screen on the front of the 5 , You might gasp in horror but my 5 is in a built in unit and can only be viewed from the front so would not look odd or out of place . I want to use the 5 as a BeoSystem 3 so will disconnect the 5’s screen and use it to drive all my Lab speakers and control the Sky with the B&o remote , also have a 7000 connected and master link Tv in the bedroom above . The Samsung screen will be direct to the Sky box via HDMI , so the only thing I will have to do is turn on/off the Samsung screen , but could program my Beo5 to do that . Should be able to connect an RF feed to the Samsung from the 5 so I can view the B&o menus when needed . the only problem I can think of is a possible sound lag because the 5 will be processing sound thru the Scart , dose anyone think this will be a problem or any other things I haven’t thought of ?
Richard
Any thoughts also on connecting a Blu-ray player , HDMI direct to the Samsung for picture but how to connect for sound ?
